Timing M with timing light?
Bob in Southwes
10-31-2001 05:46:10
Can I set the timing on my Super M with a timing light? I didn't know if anyone ever set the timing this way. I was also wondering what the correct dwell for the tractor would be.
Thanks, Bob
Bob M
10-31-2001 06:00:40
 Re: Timing M with timing light? in reply to Bob in Southwest Iowa, 10-31-2001 05:46:10
Timing an SM with a timing light is straightforward. Simply clamp the pickup (or sparkplug adapter) onto the #1 cyl plug wire. Then with the motor running at low idle, rotate the distributor until the TDC timing mark (single notch on the crank pulley rear flange) aligns with the pointer on the gear cover. Tighten dist clamp bolt and you're all set!
Don't know offhand what the dwell angle should be. But if you set the point gap at 0.020 the dwell will be good.
