1941 M
Brad
10-31-2001 06:08:34
I believe my M is one of those models that had the low compression engine. It does have the smaller gas tank that I believe was used to start and warm up the engine before switching it to tractor fuel from the large main tank. Am I right on this? If so can I switch it over to high compression pistons when I resleeve it?
Brad.
The Red
10-31-2001 08:10:36
 Re: 1941 M in reply to Brad, 10-31-2001 06:08:34
Brad check the part number on the top of the head. It is located at the middle of the head. More than likely you got the low compression head. You can use high altitude pistons to get the compression up towards 6:1 with that head.
