Sealer question
adam
11-05-2001 06:18:28
what could i use under paint to keep oil from seeping through? i have a block which i welded back up after freezing and cracking, but it still seeps something through my fresh primer, and im afraid my paint to. thanks for the help.
Stan
11-05-2001 07:58:32
 Re: sealer question in reply to adam, 11-05-2001 06:18:28
I have used JB Weld to seal up leaks in blocks, gas tanks, and you name it. It comes in 2 tubes. Just mix equal parts of the hardner and sealer together and then smear over the area where it leaks. Let it sit for a day or two to harden up before applying paint or oil.
Haas
11-05-2001 06:42:22
Use a degreaser such as Castro Super clean or the cheaper stuff that Auto Zone, etc has. Spray it on, let it set for a few minutes and then hose off. It'll help to use a stiff brush, and/or a pressure washer. Then use a good red primer before you top coat.
