Hydraulic oil level
Andy Knight
11-05-2001 18:40:49
Where and how do I check the level of the hydraulic fluid on a "M"? My lift is get slower by the day and weaker. It is around a 50 model.
Redtractorman
11-05-2001 20:53:40
 Re: Hydraulic oil level in reply to Andy Knight, 11-05-2001 18:40:49
If you have the belly pump you check the level under the gas tank on right side of tractor where you add fluid.
Dick Davis
11-06-2001 03:10:11
 Re: Re: Hydraulic oil level in reply to Redtractorman, 11-05-2001 20:53:40
They came with a dip stick to check the level at the fill neck but many have been lost over the years. The one on my H is 9 1/2" from the top of the fill pipe to the fluid level, an M would be approximately the same. Overfilling somewhat is not a big problem because the belly pump is also an expansion tank for the system. What are you using for fluid? 30wt non detergent motor oil is what the book calls for. Hope this helps, good luck. Dick
