I H 184
Ben Gittus
11-05-2001 18:43:10
Got a 184 i am working on. Has 155 lbs. compression, good spark, good fuel flow to the carb, cranks over good and quick. Pulled the new plugs i put in and none were wet. Shot in some either and will puff a little smoke at best. This tractor has been setting outside with the intake hose off the carb. I guess tomorrow i will pull off the manifold to verify that a mouse didn't crawl into the manifold and build a nest. Any suggestions or something i am overlooking??
DC
11-05-2001 21:11:33
 Re: I H 184 in reply to Ben Gittus, 11-05-2001 18:43:10
you say good fuel flow to carb. but is it filling the bowl???? Take out plug the plug in carb. bowl and see if you have fuel if not float needle is stuck.
