Keeps the rust away and fills in pits
Alabama
11-07-2001 19:18:50
Thought I would share with ya'll how I filled my badly pitted sheet metal and will prevent it from ever rusting again. I took fiberglass resin, mixed it up and applied it to the complete grill with a brush. You will be very supprised how well it coats the pits. As a side effect, if the paint ever chips or I scratch my paint job the fiberglass will protect the metal. The finish is very smooth and thick. It dries quickly too. The only thing you have to watch is runs. It takes a bit to get used to and its kind of messy but I bet that grill will out last any of the new ones out. I did not get any brush marks either. It flows into the hard to get cracks too.
Jim (Mi)
11-09-2001 04:06:38
 Re: Keeps the rust away and fills in pits in reply to Alabama, 11-07-2001 19:18:50
How does this react to high temps. Ex, coating a valve cover, or oil pan.
The Undertaker
11-08-2001 17:18:45
Bama!
Sounds like a great idea to me. What particular brand resin and what sort of preparation did you do before application? I'd follow the recommendation to post your process in the archives for it is a worthy idea.
"TU"
Paul Shuler
11-08-2001 14:07:38
Where do you get the stuff? Does it need to be sanded after it dries. Is this a bondo like product?And do you belive it will stay on the metal well or chip away in time?
scotty
11-08-2001 06:26:46
Alabama, Great post, Ive talked to a friend who
says the same thing as you about the resin flow-
ing freely without any brush marks.Thanks for
an excellent tip.
scotty
Ty
11-08-2001 05:14:47
Hey Alabama you talk about new grills in your post. Where do you find these? I need one for a 450. Thanks
Alabama
11-08-2001 10:01:21
 Re: Re: Keeps the rust away and fills in pits in reply to Ty, 11-08-2001 05:14:47
I was mainly referring to the thin sheet metal grills on new tractors and other vehicles. I have seen some real good grills on ebay, most are for the H's and M's though. I don't know of any reproduction grills out there for the 450.
sammy the RED
11-08-2001 04:54:23
You should put this on the restoration board to help the guys out.
Robert, Tulsa 50 Cub
11-09-2001 05:45:33
 Re: Re: Keeps the rust away and fills in pits in reply to sammy the RED, 11-08-2001 04:54:23
Sammy, What do you mean by "the restoration board"? Robert
