Farmall grills
BEL
11-09-2001 04:34:59
I have an early 1940 Farmall A that has a wire mesh grill. Of the same type used on industrial engines. Was this normal on some tractors in the 40`s? Thanks in advance again to all who support this great forum.
gene b
11-09-2001 05:11:03
 Re: Farmall grills in reply to BEL, 11-09-2001 04:34:59
no someone has put the grille of a combine or baler motor some of the engines had the tractor type and others used the fine mesh lots of different types I have a motor that used the C block large grille covering dipstick for oil starter generator even a plate covering up where a fuelpump could be used hope this clears it up for you
