Live hydraulics
Brad Parker
11-09-2001 05:34:43
Can anyone enlighten me on the subject of converting a 1941 M to live hydraulics? I read an article where a guy took a Super M pump which is pad mounted by the distributer and put it on his M. So he must have put the entire engine front drive section on his block? Am I correct? can it be done? Information needed. Thanks guys.
Brad
Jim Guarino, Agri-Services 716-937-6618
11-09-2001 20:57:26
 Re: Live hydraulics in reply to Brad Parker, 11-09-2001 05:34:43
I installed a M&W live pump on my Farmall H twenty years ago, and I have not had any problems at all. I have an all-hydraulic front end loader on the tractor, and it has been used extensively over the years. IH had a live pump kit listed in the parts books for the W4 and W6 tractors, which should fit the H and M respectively, if one can be found.
RedM
11-09-2001 16:52:41
I have seen dozens if not hundreds of Ms converted to live hydraulics with aftermarket parts. I can't remember who made the kits. They are easily found in salvage yards in my area. Jim Campbell in Lawrenceburg Tn had several a few weeks back when I was there.
Haas
11-09-2001 06:43:55
You can do it. However, the timing gear on the M was not designed to drive the hydraulic pump and thus is not as strong as on the Super M, so you may have trouble with the timing gear if you are using the hydraulics a lot.
artie
11-10-2001 06:37:00
 Re: Re: Live hydraulics in reply to Alabama, 11-09-2001 06:41:07
What in the world are you talking about?
These tractors had no timing chain.
