Order Farmall Cub Parts Online
Farmall Cub Three Point Hitch
Al
11-12-2001 11:53:22
I am looking for information on adding a three point hitch to a Farmall Cub. I am considering buying a Cub and would like to add a three point hitch to accept newer implements, etc. I believe that the Cubs did not come from the factory with a 3 pt Hitch. I have however seen references about adding a 3pt hitch to them. I am new to this tractor game so any information you experienced folks can provide will be appreciated. I am most interested in finding out where I can purchase the hitch, what it will cost, and what other modifications will need to be done to the tractor for the hitch to work. All pros and cons are welcome. Thanks in advance!
Douglas Stockman
11-13-2001 10:09:21
 Re: Farmall Cub Three Point Hitch in reply to Al, 11-12-2001 11:53:22
Greetings:
Just remember that a Cub can only lift about 350 pounds. Therefore, do not plan on picking up a 4 foot brush hog. Also remember that the Cub's PTO is non-standard. The shaft is different and the PTO turns in the opposite direction to a standard PTO. Therefore, your farm store PTO-powered implements will not work on a Cub.
Douglas Stockman
Penfield, NY
Al
11-13-2001 12:22:34
 Re: Re: Farmall Cub Three Point Hitch in reply to Douglas Stockman, 11-13-2001 10:09:21
Doug:
Thank you for the feedback. It was valuable.
Bob
11-12-2001 16:18:57
Hi Al,
I thought about adding a three point to my cub at one time. After searching I found that it is easier to keep my fasthitch and alter the equipment by adding the one point spike. Most of the available cub pto implements are one point. I only have the one tractor so using the one point works well for me. I'm not saying it is a bad idea but I thought I should let you know the fasthitch spikes are available. Good luck, Bob
Bob
11-12-2001 16:18:45
Hi Al,
