One Point FH Question
Bigtime299
11-18-2001 08:31:25
I have noticed some model 140's, some Super A's etc. with fast hitch that have an attachment that bolts to the pull bar underneath so you can pull a trailor or whatever. I have no idea what this is called, or where to get one, and I have looked all over. It bolts directly under the very end of the pull bar, next to where the attachments slide into the hitch. I have the mounting hole, but need to find the attachment. Any help would be greatly appreciated!
Hugh MacKay
11-19-2001 02:29:27
 Re: One Point FH Question in reply to Bigtime299, 11-18-2001 08:31:25
I have two of these tractors which I welded a piece of flat bar to the bottom of the pull bar. I placed it so protruded about 3 inches beyond the end of the pull bar. Before doing this you may want to check out that your fast hitch implements will hitch with thAT PRESENT. ( EXCUSE MY KEYBOARD) SOME WILL NOT. THE PROBLEM I HAVE ALWAYS FOUND WITH THE FACTORY PART IS THAT THE HOLE FOR THE PIN GETS EGG SHAPED VERY QUICKLY, IT RATTLES WHEN NOTHING IS HOOKED TO IT AND FEELS LIKE YOU ARE TOWING A TRAILER WITH A PIECE OF CHAIN.
Dan Robertson
11-18-2001 10:01:19
third party image
It is called an extension pull bar. My cub parts book lists the # as 520-095-R2. I would think that the 140 and the A would be the same. Does not appear that it would be to hard to fabricate one. Dan Robertson
