Front tiers 1952 H Narrow Front
Bob
11-20-2001 10:16:52
I need to replace the two front tiers on my 52 H but after removing the 3 bolts I found the ring they where bolted two is in the way.
Do I need to use a puller to remove this ring and if I do will it remove the barring ?
The Red
11-20-2001 10:35:24
 Re: Front tiers 1952 H Narrow Front in reply to Bob, 11-20-2001 10:16:52
Bob if you can jack up the tires about 6 inches off the ground, you can work that rim around the hub and get it off. If you don't want to do that, simply take off the hub cap and remove the castle nut and pull the hub assembly off the axle.
