Belly mount mower on a C
Bob(WI)
11-25-2001 15:46:08
Does anyone have or could take pictures of the mounting brackets for a belly mount mower on a C I'd really appreciate it, I'm going to try and buy a Super C I'm storing and I have a mower deck to use but need to see how they mount and figure out how to make up the mounting brackets. Thanks in advance
Rick(MN)
11-25-2001 20:35:56
 Re: Belly mount mower on a C in reply to Bob(WI), 11-25-2001 15:46:08
I have a Super C with a belly mower....if I get home before dark tommorrow I'll take a few pics and e-mail em to ya.....Rick
Bob(WI)
11-26-2001 10:47:36
 Re: Re: Belly mount mower on a C in reply to Rick(MN), 11-25-2001 20:35:56
Thanks Rick, just make sure you put mower photo's in the subject line so I know to open it as with all the viruses going around can't be to carefull.
gene b
11-25-2001 18:55:29
do you have belt pulley the mounts are different for pto than a belt pulley you dont want to run it off the pto as the bkts are harder to make
Bob(WI)
11-25-2001 19:50:17
 Re: Re: Belly mount mower on a C in reply to gene b, 11-25-2001 18:55:29
I haven't really thought about running it off the pto or belt pulley, I guess it would help to know which is easier and which will run the mower better, the mower deck I plan on useing is driven by a drive shaft hooked to a right angel gearbox on the left side of the deck if that helps, I'm still in the dreaming stage here so any help is greatly appreciated.
gene b
11-26-2001 04:25:08
 Re: Re: Re: Belly mount mower on a C in reply to Bob(WI), 11-25-2001 19:50:17
those types usually are driven of the pto you will be able to tell what the rotation ratio is this will tell which one to use
Steve Smith
11-25-2001 18:14:22
Bob
I need the same pictures. I just bought an A and I am fixing up an old three blade belly mower. I need to figure out how to mount and power the mower off the PTO. If you get any pic please let me know.
Thanks, Steve
