Farmall B motor switch
Brian
11-25-2001 20:46:53
Can you use the motor from a Farmall C and put it in a Farmall B? Everything I have on it says they are the same motor. (113C)
gene b
11-26-2001 04:20:50
 Re: Farmall B motor switch in reply to Brian, 11-25-2001 20:46:53
there are a lot of them running around redo the steering sector and you can have live hy just add a spool valve and small resivour as the C has the live pump otherwise just block of the hole in the C block whil you are at this project I would take the back frost plug out and get all the rusty stuff out of the block this would be the one on the manifold side the plug behind the filter is for the camshaft i would also pull the pan and clean the oil sump
Stan(VA).
11-26-2001 05:13:48
 Re: Re: Farmall B motor switch in reply to gene b, 11-26-2001 04:20:50
Yes to what Gene posted, with one caveat. Drill out the threaded mounting hole in the front bolster (that will be behind the behind the hyd pump in the motor) because the bolt goes in from the opposite way on the engines with hydraulics.
Stan(VA).
Will
11-26-2001 14:17:12
 Re: Re: Re: Farmall B motor switch in reply to Stan(VA)., 11-26-2001 05:13:48
And all of this gives you... ta da... a Super B that they should have built, maybe.
Redtractorman
11-25-2001 20:48:46
Yes
