Farmall C has rear axle that has play
andy
12-09-2001 21:35:39
I am going to be restoring a Farmall "C". I have used it with a belly mower. While mowing ... especially when turning I noticed that the rear axle has some play in it. You can actually see it move in and/or out from the end of the axle housing. What is the repair for this problem? I would assume that I could put shims somewhere? Thanks ... andy
W.W.
12-10-2001 05:16:29
 Re: Farmall C has rear axle that has play in reply to andy, 12-09-2001 21:35:39
the bolt that holds the bull gear on the axle is loose if the bolt falls out it could get between the bull gear and transmission and break the housing.
fix it quick
12-10-2001 11:32:13
 Re: Re: Farmall C has rear axle that has play in reply to W.W., 12-10-2001 05:16:29
fix it quick or sooner.
