Radiator shutters, standard or optional?
ATW
12-11-2001 09:35:02
Were radiator shutters standard equipment, or an option on Farmall "H" tractors. My 1947 H does'nt have them, and does'nt appear that it ever had them (except for the braket cast into the engine timing cover). A buddy of mine has a 1940 H with shutters, the control knob mounts to the rear fuel tank support. My 1947 doesn'nt have that same hole in the tank support. The only place I can see where the control knob would mount is the plate that houses the ignition switch, but that would require the control rod to be about 6"-8" longer. Is it possible someone took the system off (hard to believe considering the tractor has spent its whole life in western NY), or was this tractor just not equiped that way?
Dave_Id
12-11-2001 09:39:32
 Re: Radiator shutters, standard or optional? in reply to ATW, 12-11-2001 09:35:02
They came with the distillate engines which provided faster warmups. I'm not sure if they were optional on the "H" if you didn't have the distillate, but they were an option on "Super C's", which I have, with shutters.
ATW
12-11-2001 09:43:54
 Re: Re: Radiator shutters, standard or optional? in reply to Dave_Id, 12-11-2001 09:39:32
Thanks Dave, my machine is a gasoline model (X1 in the serial #), and my buddies 1940 is a distillate model. That clears things up alot!
The Red
12-11-2001 09:56:15
 Re: Re: Re: Radiator shutters, standard or optional? in reply to ATW, 12-11-2001 09:43:54
Yours being a gas tractor, the shutters would have not been installed as a standard feature. If it had the distillate head, then the shutters were standard.
gene b
12-11-2001 20:29:46
 Re: Re: Re: Re: Radiator shutters, standard or optional? in reply to The Red, 12-11-2001 09:56:15
hey RED there were some Hs in our neighborhood that were not distillate gas only and came with shutters our 49M came with them also some day when I SEE THE OLD DEALER IN TOWN i will ask him why seen a B the other day was a 46 it had shutters never had the tank for gas either these things are wild no rime or reason hard to say what was right or wrong think sometimes they had extra stuff and just put it on
sammy the RED
12-11-2001 12:17:58
Fuel Burning Equipment, in lieu of Standard [Includes Radiator Shutter]
Distillate, 352-473-R91
Kerosene, 352-471-R-91
Add 11 lbs. and $23.00 [1950 price]
