Restoration of Farmall A
Instrument Cluster (?)
Andy
12-12-2001 06:14:22
I'm restoring my Dad's 1940 Farmall A. There is an oblong metal box attached to the steering wheel support column. The box has no face cover, but I assume there might have been a kill switch and maybe a gauge for something mounted there.
My Farmall A manual and parts catalog shows no picture or reference to this "instrument box".
Does anyone have a pic of the intact, complete box or a parts catalog page showing it? Or who knows what it used to contain?
Note: This A has hand crank start. No battery.
Thanks!
Andy
gene b
12-13-2001 03:47:35
 Re: Restoration of Farmall A - Instrument Cluster (?) in reply to Andy, 12-12-2001 06:14:22
as JIM says no starter no control does your kill sw use the cable to short the mag or is there a sw on the throttle bracket ssome early ones used a cable running to the mag for stopping the engine
Jim Becker
12-12-2001 12:55:47
If it is hand crank with no battery, there shouldn't be lights or a generator either.* Then the box doesn't belong either. Just remove it.
* Unless it has a no-battery lighting system,, which would be very unusual.
JerryAK
12-13-2001 11:01:24
 Re: Re: Restoration of Farmall A - Instrument Cluster (?) in reply to Jim Becker, 12-12-2001 12:55:47
I have to agree with Jem B, he has it figured out. Good luck!
michael d. harris
12-12-2001 07:03:14
I believe what you are looking at is the amp guage. It tells you how much the generator or alternator is charging the battery. It should also have a small knob on it to turn the lights on and off.
EZHangin
12-12-2001 09:08:08
 Re: Re: Restoration of Farmall A - Instrument Cluster (?) in reply to michael d. harris , 12-12-2001 07:03:14
Yes, Micheal is correct.
I just re-painted my 44A.
Also did a re-wiring job.
Are the wires still there?
It is a fairly simple circuit.
Amp guage, and a rotary switch for Hi & low beam lights. The high and low beams are controlled by a resistor wired onto the rotary switch. Try a used tractor dealer.
Ontario Used Tractors near Guelph Ont. is where I shop. Should not be too hard to get.
