300 U Hydraulics
Bruce (WA)
12-12-2001 17:08:50
Still in negotiations to buy a 300 with a bad hydraulic pump. Does anyone have or know where to get a coupler to replace the pump? I could then mount a pump on front that is crank shaft driven. What models would fit?
walking tall
12-15-2001 04:59:49
 Re: 300 U Hydraulics in reply to Bruce (WA), 12-12-2001 17:08:50
YUO HAVE TO OWN THE TRACTOR BEFORE YOU CAN WORK ON IT.I HAVE A 300U AND I WOULDNT TRADE IT FOR ANYTHING.BEEN OFFERED 4500 FOR IT AND I STILL OWN IT.DOES THIS GIVE YOU A CLUE.[BUY IT FIX IT]
DunerWi
12-13-2001 06:38:02
Don't know if this will work but I would look at a coupler from a H .
Old Hand
12-13-2001 06:07:21
I have no experience with a 300U but if my memory is correct on a 400 row crop you can remove pump and bolt distribiter back on no problem.
Old Hand
12-13-2001 06:16:23
 Re: Re: 300 U Hydraulics in reply to Old Hand, 12-13-2001 06:07:21
Just rembered this required dist. drive from early SM.
LanceM
12-12-2001 19:37:48
The distributor is driven through the pump. If you disconnected the pump I think you would have problems later due to the lack of lubercation in the pump. Pumps are available, used,rebuilt, and new.
Lance
