H starting handle?
Andrew
12-12-2001 20:22:20
Friends of mine have an H. They aren't sure where the starting handle is stored on the tractor when out of use. They don't have guards on it and were thinking they should have some clips etc. to hold it to the chassis??? Any ideas?? Thanks in advance!
Bill Smith
12-15-2001 16:07:14
 Re: H starting handle? in reply to Andrew, 12-12-2001 20:22:20
There should be a sqaure piece of tubing on the front of each axel that the bolts for the draw bar goes through. This tubing should stick up a little bit past the top of the axel above the bolt hole. I always stick the handle end of the cranke down in that hole in the center of that square tubing. Never lost one yet storing it there and sometimes I use the cranke as a foot rest while driving the tractor.
Andrew
12-13-2001 17:54:48
Thank you for your replies. I have a W6 and I thought between the engine and frame but they weren't sure.
Regards
Andrew
ff316
12-13-2001 06:33:01
third party image
Go buy your self a fertilizer box. There is no better place for starting cranks, coolers, oil, tools etc...than a fertilizer box!
Old Hand
12-13-2001 06:01:24
I planted mine years ago.
F-Dean
12-13-2001 04:13:50
Andrew, "When I was growing up on the Farm" we laid the crank on "The Platform" between the shifting lever and the seat. It stayed there for years and I cannot remember ever losing a crank on an H or an M.
Farmer Bob
12-12-2001 22:19:55
I store mine behind the clutch rod and hooked over the top of the lift-all connector elbow.//FB
Bleedinred
12-12-2001 20:55:43
I put mine under the distributor between the frame rail and block.
Bruce (WA)
12-13-2001 07:49:36
 Re: Re: H starting handle? in reply to Bleedinred, 12-12-2001 20:55:43
that's where ours is and has been forever. doesn't fall off and is easy to grab.
Tom Terfehr
12-16-2001 15:03:40
 Re: Re: Re: H starting handle? in reply to Bruce (WA), 12-13-2001 07:49:36
Andy,
Thanks for your idea on stroring a farmall H hand crank. would you mind taking aminute and describing how you place in inyto the "designated slot
Thank you,
Tom
Andy Martin
12-13-2001 08:35:38
My grandpa kept his there and I see no reason to change. But it only fits in well one way.
