300 U
Bob Ralston
12-16-2001 11:59:38
does anyone have or know where a fellow can get a power steering unit for 300 U? broke a tooth off of both shafts. is it possible to have machine shop weld in new ones? Thanks
shannon
12-16-2001 18:28:54
 Re: 300 U in reply to Bob Ralston, 12-16-2001 11:59:38
had the right side tooth break once. beveled it, welded it back into place and ground it. it worked ok, but the wheel wobbles a little in 5th when you are on paved road now.
Oldster
12-16-2001 13:01:30
You can get the teeth built up at a machine shop as long as they have a pattern or a drawing to machine the weld to when welded. Is the shaft any good after the shock of breaking off the gear teeth?
bob
12-16-2001 14:32:24
 Re: Re: 300 U in reply to Oldster, 12-16-2001 13:01:30
Shaft looks good-teeth look like they have been cracked for a long time. took 1 tooth off of each shaft
