10-20 and 15-30 Serial numbers?
Andrew
12-17-2001 22:00:30
My two tractors are both missing their nameplates. I'd say they have been souvenired at some time. I can't seem to find a serial number on them anywhere. I have been able to guess as to their age from a pattern date under the chassis casting.
Does anyone have any more ideas?
Thanks
Regards
Andrew
Ken Williams
12-18-2001 11:31:45
 Re: 10-20 and 15-30 Serial numbers? in reply to Andrew, 12-17-2001 22:00:30
Andrew; On the 10-20, on the manifold side, of the engine block, there usually, but not always,is a raised, cast, boss, with the tractor serial number stamped in it, with the appropriate prefix, (KC, NC, NT). With the 15-30 and the 22-36, the same thing is true, (usually, but, not always), except this boss is on the magneto side of the block. The prefix for this series of tractors is "TG". Do not confuse this number with the engine serial number, as the engine number, will not have the the tractor model prefix.
Andrew
12-20-2001 05:19:04
 Re: Re: 10-20 and 15-30 Serial numbers? in reply to Ken Williams, 12-18-2001 11:31:45
Thanks for your reply. I'll look a bit closer and let you know the result.
Regards
Andrew
