560 D has miss
Biian in MO
12-21-2001 19:44:28
I got a 560 D but has a miss in it. The guy I got it from said it was his dads and had sat in a shed for 1 1/2 - 2yrs ran good when it was parked. I have changed fuel filters and cleaned sediment bowl, next planned to pull injecters and have them checked. Any more suggestions? I don't think its a serious motor problem but am wondering about the valves. Thanks.
the tractor vet
12-21-2001 20:07:24
 Re: 560 D has miss in reply to Biian in MO, 12-21-2001 19:44:28
It is posable that you have a valve that is stuck open or that one is stuck closed and maybe that when you ran the engine it broke a push rod, It is not hard to pull the valve cover and check everything and it would be a good time to adjust the valves i'll bet that they could use it.
spud head
12-21-2001 23:42:25
 Re: Re: 560 D has miss in reply to the tractor vet , 12-21-2001 20:07:24
You could have a stuck valve, but if it sat for a lond period of time I would be more inclined in thinking it is a dirty injector. Good luck.
