C-123
front crankshaft pulley install
Brian CNY
12-22-2001 13:53:20
I've got a Farmall 100 that I'm trying to bring back to life. I've gotten things apart, cleaned up, parts collected and I'm about to start putting it back together. The front crank pulley took alot of heat and a large puller to remove. I was just wondering if there is a trick to reassembly. I assume that I clean the pulley well and draw on with a bolt in the threaded end of the crankshaft. You probaly should try to this without heat to avoid damage to the new front seal. Am I on the right track? Are there any other tricks I should know to aid assembly of this engine? Thanks for your help.
ironhead
12-22-2001 23:21:52
 Re: C-123 - front crankshaft pulley install in reply to Brian CNY, 12-22-2001 13:53:20
put the pully in the oven . get it good and hot. the heat expands the metal. did this many times.
Dave G
12-22-2001 14:32:09
May want to freeze the crank and just warm the pulley. It all helps.
