Timing
Ben
12-23-2001 15:24:32
What is the proper way to exact time a Super M tractor. Can this be done with a timing light and the mark on the crank pulley.? where does the advance come in? Thanks
The Red
12-23-2001 15:31:03
 Re: Timing in reply to Ben, 12-23-2001 15:24:32
Ben with the engine at idle, the timing mark should line up with the pointer using the timing light. The distributor has springs to advance the timing when the engine RPM is increased. On the M with full throttle, you should see roughly 30 degrees advance.
BUD BARENIE
12-24-2001 09:53:12
 Re: Re: Timing in reply to The Red, 12-23-2001 15:31:03
RED DIFFERENT FOLLOW UP !!! I HAVE A 1953 SUPER M
PULLING IN 3MPH PULLING CLASS. HOW DO I SPEED UP MY SUPER M. RUNNING 1550RPM, ALSO 15.5-38 TIRES
RUNNING UNDER 3MPH NSPEED LIMIT. WILL 14.9-38 INCREASE SPEED + TURNING RPMS UP TO 1750, WHICH IS THE LIMIT !!! HEARING W-6 RING AND PINION WILL HELP ANY IDEA'S !!! E-MAIL CTIND@CSINET.NET
