Wide front from an M to an H
atw
12-26-2001 09:26:02
I've got a chance to pick up a wide front assembly for my H, and its local in my area. The only problem is that its from a Super M. Are the wide fronts interchangable between an H and an M?
I'm not sure what mfg it is, all I know is that the tie rods are behind the axle.
Red Rider
12-27-2001 19:42:54
 Re: Wide front from an M to an H in reply to atw, 12-26-2001 09:26:02
The only difference is the stay rod bracket. The H frame is narrower than the M. The wide fronts are the same for H through 806.
Farmer Bob
12-26-2001 12:19:03
You may have to adapt the bracketing for mounting onto the frame rails of the H. If it is a Schwartz WF you can still get the mounting hardware for the H that will bolt onto the unit.//FB
