Different motor for 1466
Ben
12-27-2001 16:22:05
I have a 1466 with a worn out motor. I have a chance to buy a DT466 motor out of a semi for a good price. Is it possible for this motor work in my 1466? Any responce will be appreciated! Thanks! Ben P.S. Could this work with 1066?
big diesel
12-27-2001 16:32:06
 Re: different motor for 1466 in reply to Ben, 12-27-2001 16:22:05
put a DT-466 from a dump truck in a 1586, all i could use was the long block, everything had to be changed from the old engine onto the truck engine, front timing cover, water pump, injection pump[wrong governor], rear engine plate, oil filters assy, fuel filter assy. exhaust manifold, front damper, flywheel. etc.
J.D. Humm
12-28-2001 15:40:29
 Re: Re: different motor for 1466 in reply to big diesel, 12-27-2001 16:32:06
Did you notice a hp difference? That sounds like an interesting project, would make a really stout 1466!
