Upper oil test cock
AL
01-01-2002 17:38:44
Where might I find the upper oil test cock for my Super H. mine is broken off and requires a vise grip.
thanks
EZHangin
01-02-2002 06:41:25
 Re: upper oil test cock in reply to AL, 01-01-2002 17:38:44
Al, not sure if the test cock on an H is the same as an A, but for my 44A, which had the same problem, I cut out the same shape as the lower test cock using a hacksack, drilled a hole through the center, just big enough to fit over that knobby that is all chewed up by the vise-grips. The final step: My buddy welded it on in 5 seconds, looks great, and simple to do.
Al
01-02-2002 09:53:08
 Re: Re: upper oil test cock in reply to EZHangin, 01-02-2002 06:41:25
Thanks that sounds good. I frankly never though about that. My dealer has one but it is not the same style and I want to stay original if possible.
Farmall Ed
01-01-2002 18:05:17
Al I bought two awhile back from the Case IH dealer in Nashville.I would think most dealers should have them.I think they cost about $3.00 each.ED
terry t in tenn
01-01-2002 19:32:11
 Re: Re: upper oil test cock in reply to Farmall Ed, 01-01-2002 18:05:17
where is the ih dealer in nashville? i in dickson thanks
Farmall Ed
01-02-2002 07:31:06
 Re: Re: Re: upper oil test cock in reply to terry t in tenn, 01-01-2002 19:32:11
McHenry Tractor is on dickerson pike/1st street no. between spring st and trinity ln.ED
