806 Hydraulic leak, HELP
Brad
01-02-2002 09:45:16
I just bought an International 806D, I took it out for a spin to put it under some load. On the way to the farm the clutch started to slip and I couldn't make the paved hill, there was a massive hydraulic leak out one of the remote valves, I mean a big leak. I'm thinking maybe losing all that fluid affected the clutch??? any and all comments will be greatly appreciated.
thanks!!
Bermuda Ken
01-02-2002 10:22:16
 Re: 806 Hydraulic leak, HELP in reply to Brad, 01-02-2002 09:45:16
Check the hyd oil level on the trans dipstick. If its low, it is not helping. Fill it. Low hyd oil levels will cause the hyd actuated T/A to not work.
Fix the remote valve leak too, its not helping either. Should be just o-rings needed to fix this.
