Serial# Tag for M
biggerred
01-04-2002 18:06:05
I have an M Farmall that has a 51 model engine(according to the number at #1 piston)and a 41 model number on the clutch housing tag. Everything else on the tractor, except the front grill(old spot weld 2 piece) is from the 51. I want to replace the tag due to its very bad condition. Which would be more correct, the 1941 serial#, or the 1951 serial#?
biggerred
01-06-2002 16:44:53
 Re: Serial# Tag for M in reply to biggerred, 01-04-2002 18:06:05
Well, I guess you good folks answered my question. I'll be sticking to the old tag. I want to be as right as I can. Thanks folks!!
Andy in Ohio
01-05-2002 21:10:47
biggerred, lots of M's and H's have different casting letters on each piece of the tractor depending on when the tractor was put together. Makes sense to stick with the correct tag on the clutch housing. Its a 41 regardless of the engine numbers. My opinion
biggerred
01-05-2002 16:25:01
I guess no one understands my question. I was asking which is more correct, the Serial# on the engine, or the one on the clutch housing/ And no, I'm not trying to make it into something that it is not, as the serial# on the engine is from a tractor that no longer lives, only the engine remains.
Old Hand
01-05-2002 18:20:07
 Re: Re: Serial# Tag for M in reply to biggerred, 01-05-2002 16:25:01
Last fall I was at a tractor show in East Tennesse. Someone had a very nice M without a serial number plate there. He had a plaque stating it was a 1944 model. Well by walking around tractor I could easily see it was a 1941 model with a 1944 engine. The axle housings, wheels, top deck, transmission housing, belt pulley and other places had 1941 casting dates only the engine was 1944. See what I mean?
sammy the RED
01-04-2002 22:31:15
If you change the serial number what will you do if you run into the guy that has the same but, correct serial number on his tractor?
Redtractorman
01-04-2002 21:29:20
The seriel # tag on the tractor is what makes it the year,changing that would be Saying its something thats it isn't.
Old Hand
01-04-2002 18:17:20
I would go with number that matches most of the casting dates. There should be at least 6 to 8 on tractor. Just my opinion.
