Farmall 300 idle problem
batman
01-09-2002 10:06:16
I have a '56 Farmall 300 that won't idle smoothly unless the choke is pulled out half way. Runs good above idle speeds. Tried carb adjustments without success. Must have an air leak somewhere, can't figure out where. Guy I bought it from had the idle speed cranked up to avoid the problem. Suggestions?
IHpuller
01-09-2002 13:00:50
 Re: Farmall 300 idle problem in reply to batman, 01-09-2002 10:06:16
id check your manifold carb gasket and your manifold gasket. take some penetrate such as pb blaster and spray it all around where the gaskets are. if you have a leak the penetrate will momentarily plug the hole and the enginge shuld rev up slightly. try that and post back. derek
