Caution Light Question
Big M
01-11-2002 04:35:41
Is it possible to change a 12 volt caution
light over to 6 volt. Or would it be worth
my time. I really need to find a way, because
I'm out plowing.
Thanks, Big M
Baggsy
01-11-2002 11:29:17
 Re: Caution Light Question in reply to Big M, 01-11-2002 04:35:41
If you're replacing a sealed beam, they can be pretty pricey I think, but the bulb/reflector types can take a new #63 bulb that only run about a quarter a piece. The old original 1133's are about $3.00 a piece out here. Do your testing with 63's...
Duey (IA)
01-11-2002 10:13:37
Big M, As Phil said, the bulb can be changed but also the flasher unit needs to be changed.
Duey
Phil Auten (Tx)
01-11-2002 06:47:16
Big M,
I'd remove the bulb and take it to a parts store. They will be able to cross reference the bulb to a 12V one to replace it with.
Phil
