International 574 D239 Wrong pistons
Bob D
01-16-2002 12:15:14
I Just completed replacing the sleeves and pistons
in my 574 with D239 engine. Now I have white
diesel smoke. I have been told by everyone I have the wrong pistons which are causing low compression. Can someone tell me the right pistons I need from Clevite and will they fit in
the sleeves I have installed? The piston and sleeves were clevite perfect circle
Les Repair
01-16-2002 16:46:29
 Re: International 574 D239 Wrong pistons in reply to Bob D, 01-16-2002 12:15:14
COMPRESSION. Get the valves and seats up to specs (or better). As OLD DUTCH said, the replacement pistons are lower compression. The new Case IH would be the same. Also not helping the compression, the new head gasket is probably different from the original, and likely thicker. Give me a call 641 847 2731.
Old-Dutch
01-16-2002 12:59:15
Bob - please belive me they have changed those pistons so many times I truly believe if you went to Germany where they were designed they would probably be in doubt. If and I do say if it did not smoke with the originals in it. I would personally pull those pistons that you put in and get a set of rings to fit the old ones and reinstall them. You might think that is silly but I will personally gaurantee you I have done it many times as a mechanic in the shop where I worked and never had any problems. Please make sure that you get the right rings as they have to be the originals with the proper bevel and istalled correctly. Feel free to ask me if you have a problem but you will not be told by your IH-Case dealer I'm sure. Upon inspecting the old and new pistons you will find the sneezer opening in the top of the piston is smaller in originals. So you see if you install low sac nozzles you are changing to conform to the other style piston. Well here we go again now if someone else were to put the right pistons back in he will have real problem to figure out. Get it? Good luck.
