300U power steering, hey Steven
big fred
01-17-2002 08:59:07
For some reason I'm unable to respond to your post below. Here's what I was trying to say:
You need a power steering gearbox out of a 300U, 350U or (so I've heard) a 460U. You will also need the safety/regulator/flow control valve from that same tractor, as the P/S safety/regulator/flow control valve includes a priority valve that isn't in the non-P/S unit. It provides priority flow to the P/S unit, which I would think is an important safety feature. Add a couple hoses, one that goes from the back of the safety/regulator/flow control valve to the P/S gearbox valve body and the other from the valve body to the reservoir, generally directly under the fast-hitch cylinder forward mounting location. To get at the steering gearbox you gotta remove the instrument panel and gas tank, and the only tough part is getting the throttle control unhooked 'cause some goofball didn't want to use a cotter pin and stuck a nail in there and bent it over real good. Good luck, and when you get your power steering gearbox, make sure you know what tractor it came off so you can get parts in the future. Good luck.
Steven
01-18-2002 04:33:47
 Re: 300U power steering, hey Steven in reply to big fred, 01-17-2002 08:59:07
Thanks for your input, the only post that I can see is yours. I visit the posts regularly and know how they work, but for some reason I can't see my post on the 300 utility.
big fred - that's odd
01-18-2002 07:01:22
 Re: Re: 300U power steering, hey Steven in reply to Steven, 01-18-2002 04:33:47
You can't see your posts? I see three of them, but I couldn't respond to any of them. Musta been some problems on the server end yesterday.
