Dry Cell 6 Volt Batt. for H?
Brian
01-18-2002 16:47:50
Does anybody have experience with Dry Cell type batteries for an H? I would appreciate any comments PRO or CON regarding use of these batteries. I think they might be a little cleaner in the long run and possibly easier to maintain. What type fits the H battery
J in PA
01-19-2002 06:11:23
 Re: Dry Cell 6 Volt Batt. for H? in reply to Brian , 01-18-2002 16:47:50
brian, i looked these batteries up on the web. they are in fact, wet cell batteries. rechargeable and long life. look them up here:
http://www.optimabatteries.com/
justin
01-18-2002 19:17:06
third party image
I used one of the Optima dry cells in an H that I restored several years ago.. These batteries are superior to the wet cells in every way.. The amount of cranking amps is greater, and they are barely affected by cold weather, and will last a LONG time without charging. If you are going to be using the tractor, I would get one.. The only problem you will find, is that there are two little square tabs on the sides that will have to be ground down so that the battery will fit in the H battery box.. I will be making the investment in two of the batteries in the next few months, that way my MV and Super C start easier...
Red Dave
01-18-2002 19:26:38
 Re: Re: Dry Cell 6 Volt Batt. for H? in reply to justin, 01-18-2002 19:17:06
justin, is that a 6 or 12 volt package?
How do they compare in price to a conventional lead/acid?
justin
01-18-2002 19:38:39
 Re: Re: Re: Dry Cell 6 Volt Batt. for H? in reply to Red Dave, 01-18-2002 19:26:38
The pic is of the 6 volt.. it comes in a 850CCA starting, or a 750CCA deep cycle.. Normal cranking amps is rated at 1,100.... They are not cheap.. They generally run in the $110-135 range, but the last one I bought only cost me the dealer cost, since it was a special order that was not picked up.. After owning that one, I don't think I will use anything else...
Red Dave
01-18-2002 18:50:06
That's a new one to me. I'm not aware of dry cells being used for that type of application.
gene b
01-18-2002 18:02:01
not enough amps to turn the starter on dry cell and how are you going to charge it
