Leaking hydraulic lines on Super C
Boondock Jones
01-19-2002 07:18:35
The metal lines on my Super C are leaking where they are attached. The leak is where the metal tubing goes into the flange/block that bolts on to the tractor. It looks like it was silver soldered or something similar from the factory. Whats the best way to repair this? Can I take off the lines remove the 0-ring seals and braze it? If so is it a job I can do myself. I've done quite a bit of brazing, but if it's delicate work I don't want to mess it up. I'd appreciate any advice, thanks. boondock
jimbo
01-19-2002 08:37:52
 Re: Leaking hydraulic lines on Super C in reply to Boondock Jones, 01-19-2002 07:18:35
Had the same problem,I tried to repair it 3-4 times and finally replaced it with a new hose.
