Which oil should I use?
300 Randy
01-21-2002 13:33:13
Could someone finally solve the oil issue for me.
My manual says to use 80/90 weight in the trans and differential on my 300U. Then I get told that I should use Hytran or I will have trouble with my TA. I need to change mine as I have a lot of water in it. Which oil should I go with? I know I would have alot less leaks with the gear oil.
Kurt
01-22-2002 02:51:18
 Re: Which oil should I use? in reply to 300 Randy, 01-21-2002 13:33:13
get the hytran.
Haas
01-21-2002 13:53:09
Use the HyTran. The TA will work better with it. It's a myth that you get less leaks with gear oil. If it's gonna leak, it'll leak with the gear oil too.
Al
01-21-2002 13:44:59
I have used hytran in my 656 for years and have no problems.
farmallgod
01-21-2002 13:37:45
Go with the hytran we ran it in our 300u and it did fine.
