Help! Carburator
AGR538
01-22-2002 05:59:40
I have a 1940 H all fuel. I took my carburator apart last night to put in a rebuild kit. When I got the bowl loose from the top I noticed that the tube in the middle was broke. I broke it because it was a new break. The name of the tube starts with a "V" but I cannot remember the name and I do not have my manual at work. I had no idea this part was in there and the IT manual did not specify it. What do I do? Can you get a replacement?
The Red
01-22-2002 07:08:08
 Re: Help! Carburator in reply to AGR538, 01-22-2002 05:59:40
If you are speaking of the large tube, that would be the venturi. Parts book is showing 2 numbers. 45118D or 64986D.
AGR538
01-22-2002 13:02:58
 Re: Re: Help! Carburator in reply to The Red, 01-22-2002 07:08:08
It is a clean break between the two halves of the carb. Do you think I need to replace it or would it seal enough when I put the carb back together?
