Replaceing the bottom radiator hose on my A??
Allan
01-22-2002 12:24:14
I think I have traced the small leak to the hose at the bottom of the radiator. Will I have to pull the whole front, shrouds and radaitor or will a new piece of hose wiggle it self in there.Any advice to put me in the right mindset will be appreicated.
Farmalldan
01-22-2002 19:43:12
 Re: replaceing the bottom radiator hose on my A?? in reply to Allan, 01-22-2002 12:24:14
Allan,
I have had some success by removing the lower water inlet casting from the front of the block. It only has 2 bolts, one of which mounts the generator adjusting strap. Be prepared to make or buy a new gasket, though.
Haas
01-22-2002 13:11:39
Probably have to pull the front grill and radiator shroud. You should then be able to squeeze a new hose in there.
