Farmall 460
Barry MO
01-23-2002 18:58:45
could someone tell me what the D & TA stands for on the shift pattern on a 460
Watch out for free wheeling!
01-24-2002 15:15:47
 Re: Farmall 460 in reply to Barry MO, 01-23-2002 18:58:45
If your brakes are not good, be careful when running with the torque amplifier pulled back...the tractor engine cannot slow you down, at least mine doesn't.
shannon
01-24-2002 13:04:10
yes d is for drive and ta is for ta. if you look real close at the emblem you will see that the d-ta is not connected to the shift pattern. i remember my first experience with a 560...spent almost a whole day trying to figure out where those two extra gears were lol.
Barry (MO)
01-24-2002 17:08:05
 Re: Re: Farmall 460 in reply to shannon, 01-24-2002 13:04:10
Thanx for the help I hauled hay out with it today and it worked great
Stan
01-24-2002 05:45:15
I'm not at home so I can't go look but I believe that it isn't so much to do with the shift pattern as it has to do with the positipon of the TA lever on the left hand side of the seat. They just put it on the shift pattern plate. With the lever forward the 460 is in direct drive and with the lever pulled back it is in a gear reduction or Torque Amplifier (TA).
LazyHorse
01-23-2002 19:19:58
D should be direct drive, and TA is torque Amplifier
