Coil too hot
Bob Pearl
03-19-1999 21:05:17
farmall 140,If I turn the switch on, my coil over heats and leaks oil. Tractor starts fine but will only run a short time then sputters off and won't start. Done tune up, carb overhaul etc. Is the coil directly wired to battery?
Bob M
03-20-1999 13:02:40
 Re: coil too hot in reply to Bob Pearl, 03-19-1999 21:05:17
Has your 140 been converted to 12 volts? If so you need to add a ballast resistor in series with the coil primary to drop voltage seen by the coil back to 6 volts.
Bob M
Ludwig
03-23-1999 13:37:11
 Re: Re: coil too hot in reply to Bob M, 03-20-1999 13:02:40
At this point it might be easier to just get a 12 volt coil.
