Super A
oil pan removel suggestions needed
Bob A
03-20-1999 15:05:30
Okay, I jumped ahead of myself. Wanted to replace the gasket on the oil pan which appeared to be leaking. Did not realize the back three bolts are not accessible. Removed the other bolts and broke the seal. Please tell me I can get to all the bolts without pulling the entire motor. If this is the only solution, can I just use the make a gasket stuff and put the oil pan back on as is without leaks?
Help appreciated.
Stan(VA).
03-20-1999 16:19:07
 Re: Super A - oil pan removel suggestions needed in reply to Bob A, 03-20-1999 15:05:30
Try a rachet wrench with about a 6" extension on it so you can reach the rear pan bolts.
Stan(VA).
ddg
03-20-1999 15:39:20
The pan shouldn't be more than a 10 min job. The flywheel cover casting at the rear of the pan should come off with just 2 bolts I think, with that out of the way you should be able to get to the rear 3 pan bolts. With that done, just go to the Case-IH dealer or maybe NAPA, get a new gasket & put the pan.
