P.T.O. on H
Bert
03-29-1999 18:18:22
I have an H and a 300 farmall I use on grain augers the 300 has live pto which works so good, can I get a live pto unit from a 300 an put it on the H and make it work
JW
03-29-1999 20:11:28
 Re: P.T.O. on H in reply to Bert, 03-29-1999 18:18:22
You could put a 300 rear end and transmission and engine in your H and have an H with live power and a TA
HR
03-30-1999 05:18:55
 Re: Re: P.T.O. on H in reply to JW, 03-29-1999 20:11:28
Bert: Good idea.. then you could call it a "Super H-TA" Hummmm.... Well.. why not..
Skip
03-29-1999 19:54:00
This will not work !!!!! The 300 pto is driven by a tube around the trns. input shaft. The H doesn't have this drive system.
Lynn (Ia)
03-30-1999 16:50:26
 Re: Re: P.T.O. on H in reply to Skip, 03-29-1999 19:54:00
This combination will work. I have seen the tractor it was done to.
Lynn (Ia)
04-01-1999 17:42:13
 Re: Re: Re: P.T.O. on H in reply to Lynn (Ia), 03-30-1999 16:50:26
Jerry Mez the owner of the Case/IH dealership had it done by his shop. He is located in Avoca, Ia. It was at a "old time tractor show" where I saw it.
Dick Davis
03-31-1999 02:55:00
Sounds as if there is some interest in such a project. Lynn do you have any details on what was requred for the installation? Can you find out and post them? Thanks.
