Need a 3 bore sleeve
Brian
04-21-1999 09:24:59
I know this sound strange but I am building a hit-n-miss engine from scratch and I need a sleeve&piston assembly with a 3" bore. Any ideas where I can get one for a decent price? Thanks...Brian ('35 F12)
Stan(VA).
04-21-1999 18:07:26
 Re: Need a 3 bore sleeve in reply to Brian, 04-21-1999 09:24:59
Is your 3" diameter for the piston or the outside of the sleeve? If for the piston, the Farmall A,B,C motors came with a 3" piston. The outside sleeve diameter down at the o-ring seal was 3 5/16", or 3 7/16" for the Super C block with the 3 1/8" piston.
Stan(VA).
Brian
04-22-1999 05:32:37
 Re: Re: Need a 3 bore sleeve in reply to Stan(VA)., 04-21-1999 18:07:26
The piston O.D. is 3". Since I am making this engine from scratch I will be reverse engineering the water hopper and so on around the sleeve itself. Is it possible to buy single sleeves? I am rebuilding my '35 F12 and it has 3" bore sleeves. But the sleeves in the F12 are good so I won't be replacing them. I just need one sleeve and matching piston. Can I order one from NAPA?
Thanks.... Brian
Stan(VA).
04-22-1999 13:17:11
 Re: Re: Re: Need a 3 bore sleeve in reply to Brian, 04-22-1999 05:32:37
Most after market places I've seen list a sleeve and piston set (4). But I know the dealer usually prices them per cylinder. You might try the host of this board and ask them for just one sleeve assy from TISCO. I don't see why they wouldn't sell individual sets for people that don't need all 4.
Stan(VA).
