1256 rear end
300winchester
02-19-2007 14:42:37
Would anyone have an idea at the cost or repairing the rear end on a 1256, or anyone know where the best place to find parts. I would do my own work
Thanks in advance
K.B.-826
02-19-2007 16:55:31
 Re: 1256 rear end in reply to 300winchester, 02-19-2007 14:42:37
Depends whats wrong and how far you want to go. A Case-IH dealer will be the best source for parts. Keep in mind that this is not exactly an easy project. Those parts are very heavy and akward to handle, and several special tools are required.
300winchester
02-20-2007 04:58:53
 Re: 1256 rear end in reply to K.B.-826, 02-19-2007 16:55:31
THe pto does not work and it jumps out of gear, would this prolbem and its severity ring a bell to you, maybe on cost and time.?
Thanks much for your reply
Mike
K.B.-826
02-20-2007 17:58:00
 Re: 1256 rear end in reply to 300winchester, 02-20-2007 04:58:53
Lucky you! Those are relatively minor problems that can be fixed on the farm. When you said "fix the rear end", I thought you were talking about removing the final drives and splitting it to tear down the whole rear end. On the PTO- first of all, do your hydraulics work? The main hyd pump is driven by the same shaft that drives the PTO unit. This shaft is driven by another shaft that splines into the clutch pressure plate. Those splines tear out from time to time. If your hydraulics work, then that is not the problem, and the PTO unit needs attention. First inspect the linkage for any obvious problems. You will need a special fitting to connect a 300 psi hyd. guage to the unit. The fitting is avalible through the parts dept. of your Case-IH dealer, don"t know the part number off the top of my head. Get yourself an I&T manual and pressure test the unit as described to pinpoint the trouble. More than likely your clutch pack is fried. The PTO unit is fairly easy to remove with the right lifting equipment, and it is possible for the ambitious do-it-yourselfer to rebuild, but a special tool is required (you can make the tool yourself). Once you reinstall the unit, you will once again need your special fitting and guage to adjust the oil pressure to the clutch pack. As far as your jumping out of gear problem, if you"re talking about jumping out of high, low, or reverse, you simply need to rebuild the range transmission cover. You"ve probably lost a detent roller and theres probably a few other worn out parts. Check the external linkage all of the way from the end of the lever to the range trans cover, replace ANYTHING that is questionable or has slop. The I&T manual should describe rebuilding the range trans cover, and I can help with any questions. If it jumps out of 1, 2, 3, or 4, thats another story.
300winchester
02-20-2007 19:11:49
 Re: 1256 rear end in reply to K.B.-826, 02-20-2007 17:58:00
Thanks so much
I do have a parts tractor that may come in handy.
May need to contact you again.
Thanks once more
