M serial number
Bar-W
02-20-2007 14:02:41
I just bought a super M,the serial number tag has
been rubbed and is not readable. Is there any other place were to look for the serial number?
Thanks
City-Boy McCoy
02-20-2007 16:02:17
 Re: M serial number in reply to Bar-W, 02-20-2007 14:02:41
Not really. But, if the Super M is like the other farmalls (I'm no SM expert) there will be a flat spot on the right side of the block under the number one spark plug with the ENGINE serial number on it. This should get you within 500 or so numbers of your tractor serial number. You can also date code your SM by looking at the casting dates on the major components. Example: "5-16-Y" = May 16, 1953. But, that will only get you within a couple of months of your tractor's birth date. Best thing to do, is clean the data plate and get a bright light and a good magnifying glass - and cross your fingers. Also, get someone else to study your data plate. For some reason, sometimes one person can visually retrieve data like this better than others. mike
