Hydraulics on '47 M
Bob Finlayson
04-23-1999 05:23:24
I'm green at this , I have a '47 "M" and was wondering how you check the hydraulic fluid level ? also , how full do you fill it ?? I know this sounds dumb , but if you know , I really would appreciate your info...THANKS !!!!
Thomas D Smith
05-21-1999 06:33:37
 Re: Hydraulics on '47 M in reply to Bob Finlayson, 04-23-1999 05:23:24
Bob, I have a "48" M the pump hold 6 quarts of hydraulic oil (I use hyd oil not 20W motor oil) ther was a good note from Lynn about the dip stick to make one from. Hope this helps.
Tom
Bob
04-24-1999 06:03:35
If I'm looking in the right spot,Over the lever, under the gas tank, sort of off to the right,the guy who owned this before me put the return line here!!! If I remove it where would I put it??(Where is it supposed to go??) Thanks again to everyone for their help!!!
john d.
04-23-1999 07:06:16
Well...some (perhaps most) of these at one time had a dipstick, but lots, (perhaps most) are missing now. If you have one, it will be found in the same place you fill it. The filler cap is on top of the center section of the tractor directly below the gas tank and above the control lever where it enters the side of the tractor. It is a knob-shaped cap which screws onto a vertical pipe that goes straight down into the pump.
I don't remember what the capacity of this pump is. If your equipment won't raise, you need more oil, and letting the pump run dry is a shortcut to a new pump. I realize that's NOT a very precise answer!!
Skip
04-23-1999 07:20:54
 Re: Re: Hydraulics on '47 M in reply to john d., 04-23-1999 07:06:16
Juust about as "precise" as it gets, most of those dipsticks were either lost or "eaten" by the pump.
Bob
04-23-1999 07:26:52
 Re: Re: Re: Hydraulics on '47 M in reply to Skip, 04-23-1999 07:20:54
Thanks for your help !!!I really appreciate it !!
Lynn (Ia)
04-23-1999 18:32:51
 Re: Re: Re: Re: Hydraulics on '47 M in reply to Bob, 04-23-1999 07:26:52
Just got back from the barn. My dipstick measures 11&1/4 inches from the top of the filler tube. The full mark is located 2" up from the bottom. This would mean that full is 9&1/4" down from the top of the filler tube. Suggest using a heavy guage wire (like #9) & bending a loop at the top & notching it at the full mark. You could then hang it on the tractor for fast checks. Hope this helps. Lynn
