Farmall 300 pushrods
Brian in southe
03-14-2007 16:35:11
My dad used my 300 row crop to blade snow the other day, said it ran fine.Got ready to use a couple days later and the engine had a miss in it when he started it.Checked everything.Pulled valve cover and it has 2 really bent pushrods and 2 slightly bent rods.Compression check has 120lbs on all cylinders,headgasket not leaking,lifters ok.Timing seems to be ok.Any ideas?
IH2444
03-15-2007 12:00:46
 Re: Farmall 300 pushrods in reply to Brian in southern Iowa, 03-14-2007 16:35:11
Water froze valve stems up ?
Janicholson
03-14-2007 17:50:22
Isit possible that Ice was formed in two cylinders, and when started bent the rods? JimN
