Paint job
1941 farmall a
03-23-2007 14:01:04
Im working on one more part right now with a lot of piting. Im gonna try and see if I can find a good way to get the pits where you cant see them.
Dandy Don
03-23-2007 22:05:50
 Re: Paint job in reply to 1941 farmall a boy, 03-23-2007 14:01:04
Farmall boy, There's a much easier way to fill pits than Bondo. I use Evercoat. It gets very hard and sands alot easier. There's also a good product called Iceing. Both need a catalyst. Directions on containers. Just follow instructions. Lots of parts houses carry both. Either is twice as fast to use as Bondo. You can start sanding in 15 or 20 minutes after application in 65 or above tempatures. Good luck. Don
georgeky
03-23-2007 15:44:08
If the pitting is not to deep you can also put on a thick coat of primer and sand it down a little until it fills up the pits. If pits are very deep Do what Rusty Farmall said.
RustyFarmall
03-23-2007 15:13:34
This will be a good time for you to experiment with body filler "bondo". A light coating on those pitted areas, and then sand it smooth. The bondo will fill the pits.
1941 farmall a boy
03-23-2007 16:23:49
 Re: Paint job in reply to RustyFarmall, 03-23-2007 15:13:34
All right ill go get me some bondo and try that im not trying to paint my hole tractor yet untell I get it runing im just doing parts hear in there giveing me some thing to do and one good thing is thay wont rust any more with the primer. Thanks all for the comments
