need an expert
banjo
03-30-2007 12:44:44
As my prior post stated i'm having difficulties with a super a final drive. I have too much play in the axle and it wears the seals out.
Main problem is the axle seal in the outter housing. I have tried to trace the problem and i have everything out in the open. My bearings slip on the axle really easy and i can feel a little wiggle while they are on the shaft.
Are these supposed to be a snug fit? by the time you get out to the tires it is quite a bit of wiggle. Could this be the problem a worn out axle?
If it is ,what are the chances of getting a good one that isn't worn out also? anyone have a measurement on what the area the bearings are on so i could compare?
Rodney E. Axford
03-30-2007 14:19:54
 Re: need an expert in reply to banjo, 03-30-2007 12:44:44
I think I maybe able to help you if you would send a personal email to me as it will be a lengthy reply if you like to do things yourself. Rodney I'm not an expert but I have had similar experiences and was successful.
