Gas line fitting
Gavin Trousdale
04-02-2007 19:20:32
I need a furl type fitting for a super A. The fitting I need is the connection between the carb. and the gas supply line. I have tried locally. No luck. Does any one know where this might be purchased.
Chad from Michigan
04-03-2007 09:18:29
 Re: Gas line fitting in reply to Gavin Trousdale, 04-02-2007 19:20:32
I was told never to use copper for gas lines because they will get brittle and break.
Now what we have been doing on the Farmall Cub Board is buying 5/16 brake line at the auto store and cutting off the ends and using the slip on compressing ring while using the 1/2-20 thread that is on the brake line. You bend your gas line where you want it and screw on the new gas line it works good.
Chad
Bob
04-03-2007 08:17:15
 New CNH part #... in reply to Gavin Trousdale, 04-02-2007 19:20:32
Old # 29 899D
New CNH # 222-503
SuperA-Tx
04-03-2007 06:34:38
OEM Tractor Parts has them for $2, part #29899D. You can also get the whole new gas line for $19 with the end fittings already on there, part # 350623R11.
I have two extra because after I bought the end fittings I decided to go ahead and replace the whole gas line. If you were close I would give them to you.
El Toro
04-03-2007 04:08:52
If that's the old compression fitting and ferrule you can get them at Home Depot. It's either 1/4" or 5/16" I would think it should be 5/16". If you need to remove the old nut and ferrule be sure to use a tube cutter. Hal
Bob
04-02-2007 20:15:14
The nut/ferrule SHOULD still be available through your local CNH dealer.
The old IH part # is 29 899D. Check if that number is still "good"; or they can probably cross it to a good number.
Jossette
04-02-2007 20:03:36
take it off and see if the propane man can fix you up with a copper line.
