Super MTA Diesel engine question
57ringo
04-03-2007 05:49:28
I have a 1954 Super MTA diesel with a bad engine and have a friend with a 1947-1948 super M diesel engine and a 1954-1955 400 diesel engine that I can buy. Will either of them fit? Would the numbers be correct?
the tractor vet
04-03-2007 06:09:42
 Re: Super MTA Diesel engine question in reply to 57ringo, 04-03-2007 05:49:28
The 400 would be a closer match and the same cu. in as what it came with as far as casting codes can't say .
georgeky
04-03-2007 06:09:12
I think either will fit, but if one is a 47 or 48 it is not a Super it will have D248 engine instead of the D264 that is for the super. The one from the 400 should be the same as the Super MD. You will have to check the numbers to see what they are.It may be possible that the 400 numbers will be a close match on the date codes.
